Use this procedure to move a vIST Leaf node pair from one DvR domain to another.
For vIST to work properly, both Leaf nodes must be in the same domain.
  1. Disable IS-IS on each vIST peer Leaf node, to remove the node from the SPB network.
    no router isis enable
  2. Disable DvR on each Leaf node.
    no dvr leaf
    Caution
    Caution
    Disabling DvR on a Leaf node in a vIST pair automatically removes all vIST configuration on that node, but not on the pair. The node on which DvR is disabled also loses its membership with the DvR domain and all the dynamic content learned from the Controllers in that domain.
    When you re-enable DvR on the node, you must manually configure vIST on that node again.
  3. Configure each node as a DvR Leaf node, with the new domain ID.
    Ensure that you configure both nodes as Leaf nodes and with the same domain ID.
    dvr leaf <1–255>
  4. Configure vIST on the DvR Leaf nodes.
    dvr leaf virtual-ist {<A.B.C.D/X|<A.B.C.D> <A.B.C.D>} peer-ip {A.B.C.D} cluster-id <1–1000>
  5. Enable IS-IS on each vIST peer Leaf node, to add back the node to the SPB network.
    router isis enable
Consider two vIST peer Leaf nodes Switch1 (IP address 51.51.51.1) and Switch2 (51.51.51.2) that belong to a DvR domain (with domain ID 4), that you need to move to another domain (with domain ID 5).
View a summary of existing Leaf configuration on each node.
Switch1:1(config)#show dvr
                      DVR Summary Info
Domain ID                      : 4
Domain ISID                    : 16678220
Role                           : Leaf
My SYS ID                      : 00:00:72:54:44:00
Operational State              : Up
GW MAC                         : 00:00:5e:00:01:25
Inband Mgmt Clip IP            :
Virtual Ist local address      : 51.51.51.1
Virtual Ist local subnet mask  : 255.255.255.0
Virtual Ist peer address       : 51.51.51.2
Virtual Ist cluster-id         : 255
Virtual Ist ISID               : 16677226
Switch2:1(config)#show dvr
                      DVR Summary Info
Domain ID                      : 4
Role                           : Leaf
My SYS ID                      : 00:00:72:55:45:00
Disable IS-IS globally on each Leaf node.
Switch1:1>en
Switch1:1>conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch1:1(config)#router isis
Switch1:1(config-isis)#no router isis enable
Switch1:1(config-isis)#exit
Switch1:1(config)#
Switch2:1>en
Switch2:1>conf t
Switch2:1(config)#router isis
Switch2:1(config-isis)#no router isis enable
Switch1:1(config)#
Disable DvR on each node. This automatically removes all vIST configuration on the node, but not on the vIST pair. The node also loses its membership with the DvR domain and all the dynamic content learned from the Controllers in that domain.
Switch1:1(config)#no dvr leaf
Switch2:1(config)#no dvr leaf
Configure each node as a DvR Leaf, with domain ID 5.
Switch1:1(config)#dvr leaf 5
Switch2:1(config)#dvr leaf 5
Configure vIST on each of the DvR Leaf nodes.
Switch1:1(config)#dvr leaf virtual-ist 51.51.51.1 peer-ip 51.51.51.2 cluster-id 255
Switch2:1(config)#dvr leaf virtual-ist 51.51.51.2 peer-ip 51.51.51.1 cluster-id 255
Enable IS-IS globally on each Leaf node.
Switch1:1(config-isis)#router isis enable
Switch1:1(config)#
Switch2:1(config-isis)#router isis enable
Switch2:1(config-isis)#exit
Switch2:1(config)#
View a summary of Leaf configuration on each node.
                      DVR Summary Info
Domain ID                      : 5
Domain ISID                    : 16678221
Role                           : Leaf
                      DVR Summary Info
Domain ID                      : 5
Role                           : Leaf
